ArcGIS.Desktop.Mapping Namespace / LasPointDisplayFilterType Enumeration
Example Example
    Coarse grained filter for display of points in a LAS dataset layer. See LasDatasetLayer.SetDisplayFilter.
    Syntax
    Members
    MemberDescription
    AllPoints Display all points.
    FirstReturnPointsDisplay only the first-return points. See ArcGIS.Core.Data.Analyst3D.LasReturnType.Return1.
    Ground Display only the points flagged as ground points.
    NonGround Display all the points that are not flagged as ground points.
    Example
    Get and Set Display Filter
      // Note: Needs QueuedTask to run
        // get the current display filter
        LasPointDisplayFilter ptFilter = lasDatasetLayer.GetDisplayFilter();
        // display only ground points
        lasDatasetLayer.SetDisplayFilter(LasPointDisplayFilterType.Ground);
        // display first return points
        lasDatasetLayer.SetDisplayFilter(LasPointDisplayFilterType.FirstReturnPoints);
        // set display filter to a set of classification codes
        List<int> classifications = new List<int>() { 4, 5, 7, 10 };
        lasDatasetLayer.SetDisplayFilter(classifications);
        // set display filter to a set of returns
        List<ArcGIS.Core.Data.Analyst3D.LasReturnType> returns = new List<ArcGIS.Core.Data.Analyst3D.LasReturnType>()
            { ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnFirstOfMany};
        lasDatasetLayer.SetDisplayFilter(returns);
        // set up a display filter
        var newDisplayFilter = new LasPointDisplayFilter();
        newDisplayFilter.Returns = new List<ArcGIS.Core.Data.Analyst3D.LasReturnType>()
            { ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnFirstOfMany, ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnLastOfMany};
        newDisplayFilter.ClassCodes = new List<int>() { 2, 4 };
        newDisplayFilter.KeyPoints = true;
        newDisplayFilter.WithheldPoints = false;
        newDisplayFilter.SyntheticPoints = false;
        newDisplayFilter.NotFlagged = false;
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.LasPointDisplayFilterType
    Requirements
    ArcGIS Pro version: 3.2 or higher.
