ArcGIS.Desktop.Editing Namespace / RowToken Class
Members Example
    RowToken Class
    A RowToken represents a feature that will be created but has not yet been created. It can be used in place of the object ID in referencing that feature even before it has an Object ID.
    Syntax
    Public NotInheritable Class RowToken
    public sealed class RowToken
    Remarks
    The RowToken can be used to chain together multiple editing primitives that depend on each other. For example, you can create two rows using Create(), and use the resulting RowTokens to create a utility network connectivity association.
    Example
    Edit Operation add attachment via RowToken
    // Creates a new feature using the specified editing template and polygon geometry, and adds an attachment to the feature in a single edit operation.
    await QueuedTask.Run(() =>
        //The EditOperation.AddAttachment method to take a RowToken as a parameter
        //allows you to create a feature, using EditOperation.CreateEx, and add an attachment in one transaction.
        EditOperation editOpAttach = new()
          Name = string.Format($@"Create new polygon with attachment in '{currentTemplate.Layer.Name}'")
        var attachRowToken = editOpAttach.Create(currentTemplate, polygon);
        editOpAttach.AddAttachment(attachRowToken, @"c:\temp\image.jpg");
        //Must be within a QueuedTask
        if (!editOpAttach.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = editOpAttach.Execute();
    Create a new Relationship and New Entities 1
      var mv = MapView.Active;
      var create_rel1 = await QueuedTask.Run(() =>
        //This example uses a chained edit operation
        var edit_op = new EditOperation()
          Name = "Create entities and a relationship",
          SelectNewFeatures = true
        //We are just going to use the GDB objects in this one but
        //we could equally use feature layers/standalone tables
        //using Feature Class/Tables (works within Investigation or map)
        var org_fc = kg.OpenDataset<FeatureClass>("Organization");
        var person_tbl = kg.OpenDataset<Table>("Person");
        //Relationship table
        var emp_tbl = kg.OpenDataset<Table>("HasEmployee");
        var attribs = new Dictionary<string, object>();
        //New Organization
        attribs["Name"] = "Acme Ltd.";
        attribs["Description"] = "Specializes in household items";
        attribs["SHAPE"] = mv.Extent.Center;//whatever is its location
        //Add it to the operation - we need the rowtoken
        var rowtoken = edit_op.Create(org_fc, attribs);
        attribs.Clear();//we are going to re-use the dictionary
        //New Person
        attribs["Name"] = "Bob";
        attribs["Age"] = "41";
        attribs["Skills"] = "Plumbing, Framing, Flooring";
        var rowtoken2 = edit_op.Create(person_tbl, attribs);
        attribs.Clear();
        //At this point we must execute the create of the entities
        if (edit_op.Execute())
          //if we are here, the create of the entities was successful
          //Next, "chain" a second create for the relationship - this ensures that
          //Both creates (entities _and_ relation) will be -undone- together if needed
          //....in other words they will behave as if they are a -single- transaction
          var edit_op_rel = edit_op.CreateChainedOperation();
          //we need the names of the origin and destination relation properties
          var kg_prop_info = kg.GetPropertyNameInfo();
          //use the row tokens we held on to from the entity creates
          attribs[kg_prop_info.OriginIDPropertyName] = rowtoken.GlobalID;
          attribs[kg_prop_info.DestinationIDPropertyName] = rowtoken2.GlobalID;
          //Add any extra attribute information for the relation as needed
          attribs["StartDate"] = new DateTimeOffset(DateTime.Now);
          //Do the create of the relate
          edit_op_rel.Create(emp_tbl, attribs);
          return edit_op_rel.Execute();
        return false;//Create of entities failed
    Create a new Relationship and New Entities 2
      var createRel = await QueuedTask.Run(() =>
        //This example uses a KnowledgeGraphRelationshipDescription
          Name = "Create entities and a relationship using a KG relate desc",
        //We are just going to use mapmembers in this example
        //we could equally use feature classes/tables
        var kg_layer = mv.Map.GetLayersAsFlattenedList()?
                      .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>().First();
        //From the KG Layer get the relevant child feature layer(s) and/or standalone
        //table(s)
        var org_fl = kg_layer.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                        .First(child_layer => child_layer.Name == "Organization");
        var person_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "Person");
        var rel_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                        .First(child_layer => child_layer.Name == "HasEmployee");
        //New Organization
        var rowtoken_org = edit_op.Create(org_fl, attribs);
        //New Person
        var rowtoken_person = edit_op.Create(person_stbl, attribs);
        attribs.Clear();
        //Create the new relationship using a KnowledgeGraphRelationshipDescription
        //Row handles act as the placeholders for the TO BE created new entities that will
        //be related
        var src_row_handle = new RowHandle(rowtoken_org);
        var dest_row_handle = new RowHandle(rowtoken_person);
        var rel_desc = new KnowledgeGraphRelationshipDescription(
                                    src_row_handle, dest_row_handle, attribs);
        //Add the relate description to the edit operation
        edit_op.Create(rel_stbl, rel_desc);
        //Execute the create of the entities and relationship
        return edit_op.Execute();
    Create a Document Record 1
      var ok = await QueuedTask.Run(() =>
        using (var kg_for_doc = kgLayer.GetDatastore())
            Name = "Create Document Example",
          var doc_entity_name = GetDocumentTypeName(kg_for_doc.GetDataModel());
          if (string.IsNullOrEmpty(doc_entity_name))
            return false;
          var hasdoc_rel_name = GetHasDocumentTypeName(kg_for_doc.GetDataModel());
          if (string.IsNullOrEmpty(hasdoc_rel_name))
            return false;
          //Document can also be FeatureClass
          var doc_tbl = kg_for_doc.OpenDataset<Table>(doc_entity_name);
          var doc_rel_tbl = kg_for_doc.OpenDataset<Table>(hasdoc_rel_name);
          //This is the document to be added...file, image, resource, etc.
          var doc_url = @"E:\Data\Temp\HelloWorld.txt";
          var text = System.IO.File.ReadAllText(url);
          //Set document properties
          attribs["contentType"] = @"text/plain";
          attribs["name"] = System.IO.Path.GetFileName(url);
          attribs["url"] = doc_url;
          //Add geometry if relevant
          //attribs["Shape"] = doc_location;
          //optional
          attribs["fileExtension"] = System.IO.Path.GetExtension(doc_url);
          attribs["text"] = System.IO.File.ReadAllText(doc_url);
          //optional and arbitrary - your choice
          attribs["title"] = System.IO.Path.GetFileNameWithoutExtension(doc_url);
          attribs["keywords"] = @"text,file,example";
          attribs["metadata"] = "";
          //Specify any additional custom attributes added to the document
          //schema by the user as needed....
          //attribs["custom_attrib"] = "Foo";
          //attribs["custom_attrib2"] = "Bar";
          //Get the entity whose document this is...
          var org_fc = kg_for_doc.OpenDataset<FeatureClass>("Organization");
          var qf = new ArcGIS.Core.Data.QueryFilter()
            WhereClause = "name = 'Acme'",
            SubFields = "*"
          var origin_org_id = Guid.Empty;
          using (var rc = org_fc.Search(qf))
            if (!rc.MoveNext())
              return false;
            origin_org_id = rc.Current.GetGlobalID();//For the relate
          //Create the document row/feature
          var rowtoken = edit_op.Create(doc_tbl, attribs);
            //Create the relationship row
            attribs.Clear();
            var kg_prop_info = kg_for_doc.GetPropertyNameInfo();
            //Specify the origin entity (i.e. the document 'owner') and
            //the document being related to (i.e. the document 'itself')
            attribs[kg_prop_info.OriginIDPropertyName] = origin_org_id;//entity
            attribs[kg_prop_info.DestinationIDPropertyName] = rowtoken.GlobalID;//document
            //Specify any custom attributes added to the has document
            //"Chain" a second create for the relationship - this ensures that
            //Both creates (doc _and_ "has doc" relation) will be -undone- together if needed
            edit_op_rel.Create(doc_rel_tbl, attribs);
          return false;
    string GetDocumentTypeName(KnowledgeGraphDataModel kg_dm)
      var entity_types = kg_dm.GetEntityTypes();
      foreach (var entity_type in entity_types)
        var role = entity_type.Value.GetRole();
        if (role == KnowledgeGraphNamedObjectTypeRole.Document)
          return entity_type.Value.GetName();
      return "";
    string GetHasDocumentTypeName(KnowledgeGraphDataModel kg_dm)
      var rel_types = kg_dm.GetRelationshipTypes();
      foreach (var rel_type in rel_types)
        var role = rel_type.Value.GetRole();
          return rel_type.Value.GetName();
      return "";
    Create utility network features and associations in a single edit operation
      // This routine creates a pole and a transformer bank, and then creates a structural attachment association between them, all in a single edit operation
      static void CreateUNFeaturesAndAssociations(FeatureLayer transformerBankLayer,
      Dictionary<string, object> transformerBankAttributes, FeatureLayer poleLayer,
      Dictionary<string, object> poleAttributes)
        // Create an EditOperation
        EditOperation editOperation = new EditOperation();
        editOperation.Name = "Create pole; create transformer bank; attach transformer bank to pole";
        // Create the transformer bank
        RowToken transformerBankToken = editOperation.Create(transformerBankLayer, transformerBankAttributes);
        // Create a pole
        RowToken poleToken = editOperation.Create(poleLayer, poleAttributes);
        // Create a structural attachment association between the pole and the transformer bank
        RowHandle poleHandle = new RowHandle(poleToken);
        RowHandle transformerBankHandle = new RowHandle(transformerBankToken);
        AssociationDescription poleAttachment =
          new AssociationDescription(AssociationType.Attachment, poleHandle, transformerBankHandle);
        editOperation.Create(poleAttachment);
        // Execute the EditOperation
        editOperation.Execute();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Editing.RowToken
    Requirements
