ArcGIS.Core.Data Namespace / DatabaseClient Class / GetDatabaseConnectionProperties Method
A valid database connection file.
Example
    Syntax
    Public Shared Function GetDatabaseConnectionProperties( _
       ByVal databaseConnectionFile As DatabaseConnectionFile _
    ) As DatabaseConnectionProperties
    public static DatabaseConnectionProperties GetDatabaseConnectionProperties(
       DatabaseConnectionFile databaseConnectionFile
    Parameters
    Return Value
    The corresponding DatabaseConnectionProperties.
    Exceptions
    ExceptionDescription
    databaseConnectionFile is null.
    The information used to connect to the geodatabase is invalid.
    A geodatabase-related exception has occurred.
    Example
    Getting Database Connection Properties from a Connection File
      DatabaseConnectionFile connectionFile =
        new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"));
      DatabaseConnectionProperties connectionProperties =
        DatabaseClient.GetDatabaseConnectionProperties(connectionFile);
      // Now you could, for example, change the user name and password in the connection properties prior to use them to open a geodatabase
    Requirements
