Public ReadOnly Property TextGraphic As CIMTextGraphic
public CIMTextGraphic TextGraphic {get;}
// Modifies the text graphic of a selected annotation feature in the specified annotation layer. await QueuedTask.Run(() => { var selection = annotationLayer.GetSelection(); if (selection.GetCount() == 0) return; // use the first selected feature var insp = new Inspector(); insp.Load(annotationLayer, selection.GetObjectIDs().FirstOrDefault()); // getAnnoProperties should return null if not an annotation feature AnnotationProperties annoProperties = insp.GetAnnotationProperties(); // get the textGraphic CIMTextGraphic textGraphic = annoProperties.TextGraphic; // change text textGraphic.Text = "Hello world"; // set x,y offset via the symbol var symbol = textGraphic.Symbol.Symbol; var textSymbol = symbol as CIMTextSymbol; textSymbol.OffsetX = 2; textSymbol.OffsetY = 3; textSymbol.HorizontalAlignment = HorizontalAlignment.Center; // load the updated textGraphic annoProperties.LoadFromTextGraphic(textGraphic); // assign the annotation properties back insp.SetAnnotationProperties(annoProperties); EditOperation op = new EditOperation { Name = "modify symbol" }; op.Modify(insp); if (!op.IsEmpty) { bool result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
