Public Class KnowledgeGraphLayerCreationParams Inherits LayerCreationParams
public class KnowledgeGraphLayerCreationParams : LayerCreationParams
await QueuedTask.Run(() =>
//With a connection to a KG established or source uri available...
//Create a KnowledgeGraphLayerCreationParams
var kg_params = new KnowledgeGraphLayerCreationParams(kg)
Name = "KG_With_All_Types",
IsVisible = false
//Or
var kg_params2 = new KnowledgeGraphLayerCreationParams(new Uri(url))
IsVisible = false
//Call layer factory with map or group layer container.
//A KG layer containing a feature layer and/or standalone table per
//entity and relate type (except provenance) is created
var kg_layer = LayerFactory.Instance.CreateLayer<KnowledgeGraphLayer>(
kg_params, map);
//To create a KG layer (on a map or link chart) with a subset of
//entities and relates, you must create an "id set". The workflow
//is very similar to how you would create a SelectionSet.
//First, create a dictionary containing the names of the types to be
//added plus a corresponding list of ids (just like with a selection set).
//Note: null or an empty list means add all records for "that" type..
var kg_datamodel = kg.GetDataModel();
//Arbitrarily get the name of the first entity and relate type
var first_entity = kg_datamodel.GetEntityTypes().Keys.First();
var first_relate = kg_datamodel.GetRelationshipTypes().Keys.First();
//Make entries in the dictionary for each
var dict = new Dictionary<string, List<long>>();
dict.Add(first_entity, new List<long>());//Empty list means all records
dict.Add(first_relate, null);//null list means all records
//or specific records - however the ids are obtained
//dict.Add(entity_or_relate_name, new List<long>() { 1, 5, 18, 36, 78});
//Create the id set...
var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict);
//Create the layer params and assign the id set
Name = "KG_With_ID_Set",
IsVisible = false,
IDSet = idSet
//A KG layer containing just the feature layer(s) and/or standalone table(s)
//for the entity and/or relate types + associated records will be created
kg_params, map);
//Feature class and/or standalone tables representing KG entity and
//relate types can only be added to a map (or link chart) as a child
//of a KnowledgeGraph layer....
//For example:
var fc = kg.OpenDataset<FeatureClass>("Some_Entity_Or_Relate_Name");
try
//Attempting to create a feature layer containing the returned fc
//is NOT ALLOWED - can only be a child of a KG layer
var fl_params_w_kg = new FeatureLayerCreationParams(fc);
//CanCreateLayer will return false
if (!(LayerFactory.Instance.CanCreateLayer<FeatureLayer>(
fl_params_w_kg, map)))
System.Diagnostics.Debug.WriteLine(
$"Cannot create a feature layer for {fc.GetName()}");
return;
//This will throw an exception
LayerFactory.Instance.CreateLayer<FeatureLayer>(fl_params_w_kg, map);
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex.ToString());
//Can only be added as a child of a parent KG
dict.Add(fc.GetName(), new List<long>());
Name = $"KG_With_Just_{fc.GetName()}",
IsVisible = false,
IDSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict)
kg_params, map);
System.Object
ArcGIS.Desktop.Mapping.BaseCreationParams
ArcGIS.Desktop.Mapping.MapMemberCreationParams
ArcGIS.Desktop.Mapping.LayerCreationParams
ArcGIS.Desktop.Mapping.KnowledgeGraphLayerCreationParams
