ArcGIS.Desktop.Mapping Namespace / SurfaceLayer Class / CanGetLineOfSight Method
A set of parameters that will be used to calculate the Line of Sight.
Example
    CanGetLineOfSight Method (SurfaceLayer)
    Determines whether a Line of Sight analysis can be calculated for the given set of parameters. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CanGetLineOfSight( _
       ByVal lineOfSightParams As LineOfSightParams _
    ) As Boolean
    public bool CanGetLineOfSight(
       LineOfSightParams lineOfSightParams
    Parameters
    lineOfSightParams
    Return Value
    True if checks pass. False otherwise.
    Remarks
    It is important to call this method prior to GetLineOfSight to ensure that a possible result can be found given the set of input parameters. In addition to checking for valid observer and target points (that is they have x,y coordinates) and non NaN observer height, target height and refraction factors, the observer and target points must also lie within the extent of the surface's area. This method also checks for a 3D Analyst license which is required to perform the analysis. Finally if LineOfSightParams.ApplyCurvature or LineOfSightParams.ApplyRefraction are set to true, then the spatial reference of the surface needs to be in a projected coordinate system and have Z coordinate units defined.
    Note that if this method returns true it does not preclude the GetLineOfSight method from throwing an exception due to a calculation error and callers should code defensively and use appropriate exception handling.
    Example
    Get Line of Sight
      tinLayer = null;
      MapPoint observerPoint = null;
      MapPoint targetPoint = null;
      CIMPointSymbol obstructionPointSymbol = null;
      CIMLineSymbol visibleLineSymbol = null;
      CIMLineSymbol invisibleLineSymbol = null;
      var losParams = new LineOfSightParams();
      losParams.ObserverPoint = observerPoint;
      losParams.TargetPoint = targetPoint;
      // add offsets if appropriate
      // losParams.ObserverHeightOffset = observerOffset;
      // losParams.TargetHeightOffset = targerOffset;
      // add obstruction feature class if appropriate (multipatch)
      //losParams.ObstructionsMultipatchFeatureClass = obsFeatureClass;
      // set output spatial reference
      losParams.OutputSpatialReference = MapView.Active.Map.SpatialReference;
      LineOfSightResult results = null;
      try
        // Note: Needs QueuedTask to run
          if (tinLayer.CanGetLineOfSight(losParams))
            results = tinLayer.GetLineOfSight(losParams);
      catch (Exception)
        // handle exception
      if (results != null)
        bool targetIsVisibleFromObserverPoint = results.IsTargetVisibleFromObserverPoint;
        //These properties are not used. They will always be false
        // results.IsTargetVisibleFromVisibleLine;
        // results.IsTargetVisibleFromInvisibleLine;
        if (results.VisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, visibleLineSymbol.MakeSymbolReference());
        if (results.InvisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, invisibleLineSymbol.MakeSymbolReference());
        if (results.ObstructionPoint != null)
          MapView.Active.AddOverlay(results.ObstructionPoint, obstructionPointSymbol.MakeSymbolReference());
    Requirements
    ArcGIS Pro version: 3.2 or higher.
