ArcGIS.Core.Data Namespace / Geodatabase Class / GetAttributeRuleManager Method
    Gets the AttributeRuleManager associated with this geodatabase if it supports attribute rules. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetAttributeRuleManager() As AttributeRuleManager
    public AttributeRuleManager GetAttributeRuleManager()
    Return Value
    The AttributeRuleManager associated with this geodatabase if it supports attribute rules.
    Exceptions
    ExceptionDescription
    This geodatabase does not support attribute rules.
    Remarks
    If IsAttributeRuleSupported returns false, calling this method will result in an exception.
    Requirements
