ArcGIS.Core.Data.PluginDatastore Namespace / PluginDatasourceTemplate Class / Close Method
    Close Method (PluginDatasourceTemplate)
    Formally closes the Plugin Datasource. This operation is the opposite of Open.
    Syntax
    Public MustOverride Sub Close()
    public abstract void Close()
    Remarks
    • When the framework calls this method, the concrete implementation is expected to perform any necessary housekeeping and cleanup operation to close the plug-in data source.
    • The framework will ignore any exception that is raised by the concrete implementation.
    Requirements
