ArcGIS.Core.Data.PluginDatastore Namespace / PluginDatasourceTemplate Class / GetDatasourceDescription Method
A value indicating whether the description should be in singular or plural form.
    Gets a string description for the plug-in data source depending on inPluralForm.
    Syntax
    Public Overridable Function GetDatasourceDescription( _
       ByVal inPluralForm As Boolean _
    ) As String
    public virtual string GetDatasourceDescription(
       bool inPluralForm
    Parameters
    inPluralForm
    Return Value
    A name description for the plug-in data source. The default is Plugin Datasources if inPluralForm is true, Plugin Datasource if false.
    Requirements
