ArcGIS.Core.Data.PluginDatastore Namespace / PluginDatasourceTemplate Class / GetTableNames Method
    GetTableNames Method (PluginDatasourceTemplate)
    Gets the name of all the tables and feature classes that exist in the currently opened plug-in data source.
    Syntax
    Public MustOverride Function GetTableNames() As IReadOnlyList(Of String)
    public abstract IReadOnlyList<string> GetTableNames()
    Return Value
    A IReadOnlyList of table names.
    Exceptions
    ExceptionDescription
    Signals to the framework that an exception derived from System.Exception has occurred.
    Remarks
    These plug-in tables and feature classes do not necessarily correspond to database tables on the back end. They can be any data structure or format in the third-party data source, but are presented to ArcGIS as a table via the Plugin Datasource.
    The concrete implementation will decide whether the returned table names are fully qualified or unqualified as long as the names can be successfully used as arguments to OpenTable.
    Requirements
