ArcGIS.Core.Data.PluginDatastore Namespace / PluginTableTemplate Class / IsNativeRowCountSupported Method
    Gets a value indicating whether the plug-in table or feature class supports row count natively.
    Syntax
    Public Overridable Function IsNativeRowCountSupported() As Boolean
    public virtual bool IsNativeRowCountSupported()
    Return Value
    true if the plug-in table or feature class supports row count natively; otherwise, false. The default is false.
    Remarks
    The reason why concrete implementations of this abstraction should overwrite this method and GetNativeRowCount (if the underlying data source supports native row count) is strictly for performance reasons. If this method returns false and a row count is needed for the plug-in table, the framework will call the Search method on the entire plug-in table and then manually iterate through the cursor to determine the number of rows.
    Requirements
