ArcGIS.Core.CIM Namespace / CIMKeyframeCamera Class
    CIMKeyframeCamera Class Properties
    For a list of all members of this type, see CIMKeyframeCamera members.
    Public Properties
     NameDescription
    Public Property Gets or sets the bezier control points between the previous camera position and the current camera position. Used to define the camera path for the AdjustableArc transition. When the value is null or empty, a default path is used. Must be in the map's spatial reference.
    Public Property Gets or sets the camera for the keyframe.
    Public Property Gets or sets the transition mode determines whether the camera path follows a Geodesic or Cartesian interpolation.
    Public Property Gets or sets the field of view angle. Only applies to scene views.
    Public Property Gets or sets the method of transition for the field of view of the camera.
    Public Property Gets or sets the method of transition for the heading of the camera.
    Public Property Gets or sets a geometry for the camera to look at. When a geometry is set it overrides the camera's heading and pitch. Must be in the map's spatial reference.
    Public Property Gets or sets the method of transition for the pitch of the camera.
    Public Property Gets or sets the method of transition for the roll of the camera.
    Public Property Gets or sets the method of transition for the scale of the camera.
    Public Property Gets or sets the value of adjustable transitions. The value must be between 0.0 and 1.0. Smaller values will result in a tighter / smaller curve than larger values.
    Public Property Gets or sets the method of transition for the x of the camera.
    Public Property Gets or sets the method of transition for the y of the camera.
    Public Property Gets or sets the method of transition for the z of the camera.
    Top
