Public Function GetDatastore() As KnowledgeGraph
public KnowledgeGraph GetDatastore()
Return Value
The knowledge graph datastore associated with the layer. Returns null if the KnowledgeGraph layer is empty.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//var kgLayer = MapView.Active.Map.GetLayersAsFlattenedList()
// .OfType<KnowledgeGraphLayer>().FirstOrDefault();
await QueuedTask.Run(() =>
// use the layer directly
KnowledgeGraph datastore = kgLayer.GetDatastore();
// or you can use any of the sub items since
//KnowledgeGraphLayer is a composite layer - get the first
// child feature layer or standalone table
var featlayer = kgLayer?.GetLayersAsFlattenedList()?
.OfType<FeatureLayer>()?.FirstOrDefault();
KnowledgeGraph kg = null;
if (featlayer != null)
using (var fc = featlayer.GetFeatureClass())
kg = fc.GetDatastore() as KnowledgeGraph;
//TODO use KnowledgeGraph
else
//try standalone table
var stbl = kgLayer?.GetStandaloneTablesAsFlattenedList()?
.FirstOrDefault();
if (stbl != null)
using (var tbl = stbl.GetTable())
kg = tbl.GetDatastore() as KnowledgeGraph;
var kg_layer = MapView.Active.Map.GetLayersAsFlattenedList()
if (kg_layer == null)
return;
// get the datastore
var kg = kg_layer.GetDatastore();
// now submit a search or a query
// kg.SubmitSearch
// kg.SubmitQuery
