ArcGIS.Core.CIM Namespace / CIMFilteredFindPathsPathFilter Class
Properties Methods Events
    CIMFilteredFindPathsPathFilter Class Members
    The following tables list the members exposed by CIMFilteredFindPathsPathFilter.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the filter type of the path filter.
    Public Property Gets or sets the id of the entity/relationship instance used for the path filter. If this id is null, then the path filter is used on all instances of the specified entity/relationship type.
    Public Property Gets or sets whether the path filter is used for entities or relationships.
    Public Property Gets or sets the type name of the entity/relationship (type or instance) used for the path filter.
    Public Property Gets or sets the property filter predicate (openCypher syntax) associated with the path filter. The predicate is only taken into account when ID has no value.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFilteredFindPathsPathFilter.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFilteredFindPathsPathFilter with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFilteredFindPathsPathFilter and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
