ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphSpatialProperty Class
    CIMKnowledgeGraphSpatialProperty Class Properties
    For a list of all members of this type, see CIMKnowledgeGraphSpatialProperty members.
    Public Properties
     NameDescription
    Public Property Gets or sets the geometry type of the property. Currently, only allowed values: - esriGeometryPoint - esriGeometryMultipoint - esriGeometryPolyline - esriGeometryPolygon Others will be allowed in future.
    Public Property Gets or sets a value indicating whether all geometry values should be kept when merging. Only applies when GeometryType is a multi-part geometry.
    Public Property Gets or sets a value indicating whether this property should be used to determine a merge. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets the value to use when import data is missing. This value is used when the Value property results in a null or empty value. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets the name of the property. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets the type of the property. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Public Property Gets or sets a value describing how to handle spatial merge. If not set, there is no spatial merge.
    Public Property Gets or sets the spatial reference of the property.
    Public Property Gets or sets the value which is to be imported. Value will have to be tested for type in order to properly perform the import. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphProperty)
    Top
