ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / GetLinkChartLayout Method
Example
    Gets the layout algorithm for the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function GetLinkChartLayout( _
       ByVal mapView As MapView _
    ) As KnowledgeLinkChartLayoutAlgorithm
    public static KnowledgeLinkChartLayoutAlgorithm GetLinkChartLayout(
       MapView mapView
    Parameters
    mapView
    Return Value
    The link chart layout algorithm.
    Exceptions
    ExceptionDescription
    Map cannot be null.
    Map is not a link chart.
    Example
    Get and set the link chart layout
      //var map = MapView.Active.Map;
      // a MapView can encapsulate a link chart IF it's map
      // is of type MapType.LinkChart
      var isLinkChart = map.MapType == MapType.LinkChart;
      // or use the following
      // var isLinkChart = map.IsLinkChart;
      var mv = MapView.Active;
      await QueuedTask.Run(() =>
        if (isLinkChart)
          // get the layout algorithm
          var layoutAlgorithm = mv.GetLinkChartLayout();
          // toggle the value
          if (layoutAlgorithm == KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard)
            layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Organic_Standard;
          else
            layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard;
          // set it
          mv.SetLinkChartLayoutAsync(layoutAlgorithm);
          // OR set it and force a redraw / update
          // await mv.SetLinkChartLayoutAsync(layoutAlgorithm, true);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
