Public NotInheritable Class KnowledgeGraphLayerIDSet
public sealed class KnowledgeGraphLayerIDSet
// get the active investigation view
var iv = KnowledgeGraphInvestigationView.Active;
var serviceUri = iv.Investigation.ServiceUri;
// build a dictionary of records
string some_entity = "Entity_Type_Name";
var dict = new Dictionary<string, List<long>>();
//Each entry consists of the type name and corresponding lists of ids
dict.Add(some_entity, new List<long>() { 1, 5, 18, 36, 78 });
//Create the id set...
var idSet = KnowledgeGraphLayerIDSet.FromDictionary(new Uri(serviceUri), dict);
// select the records on the investigation view
iv.SetSelectedRecords(idSet, SelectionCombinationMethod.New);
// clear the selected records
iv.ClearSelectedRecords();
await QueuedTask.Run(() =>
// get the investigation
var inv = iv.Investigation;
// get the set of selected records
var idSet = iv.GetSelectedRecords();
// view these records in a link chart
var map = MapFactory.Instance.CreateLinkChart("myLinkChart", new Uri(inv.ServiceUri), idSet);
ProApp.Panes.CreateMapPaneAsync(map);
// get the selection set
var sSet = map.GetSelection();
// translate to an KnowledgeGraphLayerIDSet
// if the selectionset does not contain any KG entity or relationship records
// then idSet will be null
var idSet = KnowledgeGraphLayerIDSet.FromSelectionSet(sSet);
if (idSet == null)
return;
// you can use the idSet to create a new linkChart
// (using MapFactory.Instance.CreateLinkChart)
System.Object
ArcGIS.Desktop.Mapping.KnowledgeGraphLayerIDSet
