ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / SetLinkChartLayoutAsync Method / SetLinkChartLayoutAsync(MapView,KnowledgeLinkChartLayoutAlgorithm,Boolean) Method
The link chart layout algorithm
Force an update to occur. Default value is false.
Example
    Sets the layout algorithm for the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Shared Function SetLinkChartLayoutAsync( _
       ByVal mapView As MapView, _
       ByVal algorithm As KnowledgeLinkChartLayoutAlgorithm, _
       ByVal forceLayoutUpdate As Boolean _
    ) As Task
    Parameters
    mapView
    algorithm
    forceLayoutUpdate
    Exceptions
    ExceptionDescription
    Map cannot be null.
    Map is not a link chart.
    Example
    Get and set the link chart layout
      //var map = MapView.Active.Map;
      // a MapView can encapsulate a link chart IF it's map
      // is of type MapType.LinkChart
      var isLinkChart = map.MapType == MapType.LinkChart;
      // or use the following
      // var isLinkChart = map.IsLinkChart;
      var mv = MapView.Active;
      await QueuedTask.Run(() =>
        if (isLinkChart)
          // get the layout algorithm
          var layoutAlgorithm = mv.GetLinkChartLayout();
          // toggle the value
          if (layoutAlgorithm == KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard)
            layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Organic_Standard;
          else
            layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard;
          // set it
          mv.SetLinkChartLayoutAsync(layoutAlgorithm);
          // OR set it and force a redraw / update
          // await mv.SetLinkChartLayoutAsync(layoutAlgorithm, true);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
