ArcGIS.Core.CIM Namespace / CIMWaterFill Class
    CIMWaterFill Class Properties
    For a list of all members of this type, see CIMWaterFill members.
    Public Properties
     NameDescription
    Public Property Gets or sets the animations that are applied to the symbol layer. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the intrinsic color of the water.
    Public Property Gets or sets a value indicating whether the color set at the basic properties level is applied to the symbol layer. If the symbol layer is color locked then changes made to the color in the basic properties will not be applied to the symbol layer. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets whether the geometric effects that are applied to the symbol layer. Effects dynamically alter the feature geometry when the symbology is applied. Multiple effects applied to a symbol layer are rendered sequentially. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets a value indicating whether the symbol layer is visible. The symbol layer draws only when enabled. Currently, an invisible layer is not considered in any transformations when in a 3D context. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the internal name of the symbol layer used for symbol level drawing. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets a value indicating whether or not the symbol layer should overprint in press printing. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the waterbody size allowing for a range of sizes from small pools to oceans. This property along with wave strength are the parameters which drive the wave appearance.
    Public Property Gets or sets the azimuthal bearing for direction of the waves. Only has effect when WasHasDirection is true.
    Public Property Gets or sets a value indicating whether the waves are directionless (false), or if they have a dominant direction (true).
    Public Property Gets or sets the strength of the waves. This property along with waterbody size are the parameters which drive the wave appearance.
    Top
