ArcGIS.Core.Data.PluginDatastore Namespace / PluginDatasourceTemplate Class / CanOpen Method
The connection path to the actual data source.
    CanOpen Method (PluginDatasourceTemplate)
    Gets a value indicating whether the data source associated with connectionPath can be opened by this concrete implementation.
    Syntax
    Public Overridable Function CanOpen( _
       ByVal connectionPath As Uri _
    ) As Boolean
    public virtual bool CanOpen(
       Uri connectionPath
    Parameters
    connectionPath
    Return Value
    true if the data source associated with connectionPath can be opened; otherwise, false. The default is false.
    Remarks
    From time to time, some subsystems in ArcGIS Pro may need to query this method to determine whether a path to a data source can be opened by a data store, plugin or otherwise. For example, the geoprocessing subsystem may call this method as part of its "post tool execution". If this method returns true, geoprocessing may proceed to instantiate this plug-in data source in order to perform some system-specific tasks.
    Requirements
