ArcGIS.Core.Geometry Namespace / MultipatchBuilderEx Class / HasM Property
Example
    HasM Property (MultipatchBuilderEx)
    Gets or sets a value indicating if the MultipatchBuilderEx recognizes M-values also known as M-awareness.
    Syntax
    Public Overrides NotOverridable Property HasM As Boolean
    public override bool HasM {get; set;}
    Remarks
    When HasM is false, the M-value is always NaN.
    Example
    Construct Multipatch from another Multipatch
      TextureResource brickTextureResource = null;
      BasicMaterial brickMaterialTexture = new BasicMaterial();
      var coords = new List<Coordinate3D>();
      // create the multipatchBuilderEx object
      var builder = new ArcGIS.Core.Geometry.MultipatchBuilderEx(multipatch);
      // check some properties
      bool hasM = builder.HasM;
      bool hasZ = builder.HasZ;
      bool hasID = builder.HasID;
      bool isEmpty = builder.IsEmpty;
      bool hasNormals = builder.HasNormals;
      var patches = builder.Patches;
      int patchCount = patches.Count;
      // if there's some patches
      if (patchCount > 0)
        int pointCount = builder.GetPatchPointCount(0);
        // replace the first point in the first patch
        if (pointCount > 0)
          // get the first point
          var pt = builder.GetPoint(0, 0);
          builder.SetPoint(0, 0, mapPoint);
        // check which patches currently contain the texture
        var texture = builder.QueryPatchIndicesWithTexture(brickTextureResource);
        // assign a texture material
        patches[0].Material = brickMaterialTexture;
      // update the builder for M awareness
      builder.HasM = true;
      // synchronize the patch attributes to match the builder attributes
      //   in this instance because we just set HasM to true on the builder, each patch will now get a default M value for it's set of coordinates
      builder.SynchronizeAttributeAwareness();
      // call ToGeometry to get the multipatch
      multipatch = builder.ToGeometry() as Multipatch;
      // multipatch.HasM will be true
    Requirements
