ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / GetShowRootNodes Method
Example
    Gets whether root nodes are displayed for the link chart map view.
    Syntax
    Public Shared Function GetShowRootNodes( _
       ByVal mapView As MapView _
    ) As Boolean
    public static bool GetShowRootNodes(
       MapView mapView
    Parameters
    mapView
    Return Value
    A boolean indicating if root nodes are displayed.
    Exceptions
    ExceptionDescription
    Map cannot be null.
    Map is not a link chart.
    Example
    Toggle Root Node Display
      var val = MapView.Active.GetShowRootNodes();
      await QueuedTask.Run(() =>
        MapView.Active.SetShowRootNodes(!val);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
