ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / SelectAllRootNodes Method
Example
    Selects the existing set of root nodes defined on the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function SelectAllRootNodes( _
       ByVal mapView As MapView _
    ) As SelectionSet
    public static SelectionSet SelectAllRootNodes(
       MapView mapView
    Parameters
    mapView
    Return Value
    The set of root nodes as a SelectionSet
    Exceptions
    ExceptionDescription
    Map cannot be null.
    Map is not a link chart.
    Example
    Select the records that are Root Node
      await QueuedTask.Run(() =>
        var mapSel = MapView.Active.SelectAllRootNodes();
        // this is the same as
        MapMemberIDSet rootNodes = MapView.Active.GetRootNodes();
        SelectionSet selSet = SelectionSet.FromMapMemberIDSet(rootNodes);
        MapView.Active.Map.SetSelection(selSet);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
