ArcGIS.Desktop.Core Namespace / ExploratoryAnalysisOptions Class / SetElevationProfileOptionsAsync Method
The new elevation profile options
Example
    Sets the elevation profile options.
    Syntax
    Public Function SetElevationProfileOptionsAsync( _
       ByVal elevationProfileOptions As ElevationProfileOptions _
    ) As Task
    public Task SetElevationProfileOptionsAsync(
       ElevationProfileOptions elevationProfileOptions
    Parameters
    Exceptions
    ExceptionDescription
    elevationProfileOptions is null.
    Elevation profile options are not valid. See CanSetElevationProfileOptions for details on option settings.
    Remarks
    This method calls the CanSetElevationProfileOptions function prior to setting the option values. If the options are invalid, no updates are made.
    Example
    Customize Elevation Profile Graph Display
        // customize the elevation profile graph options
        var options = new ElevationProfileOptions()
            LineColor = ColorFactory.Instance.CreateRGBColor(0, 0, 100),
            ShowAverageSlope = false,
            ShowMaximumSlope = false
        var eaOptions = ApplicationOptions.ExploratoryAnalysisOptions;
        if (eaOptions.CanSetElevationProfileOptions(options))
            await eaOptions.SetElevationProfileOptionsAsync(options);
        // or reset to default options
        var defaultOptions = eaOptions.GetDefaultElevationProfileOptions();
        if (eaOptions.CanSetElevationProfileOptions(defaultOptions))
            await eaOptions.SetElevationProfileOptionsAsync(defaultOptions);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
