ArcGIS.Core.Data.Topology Namespace / TopologyEdge Class
    TopologyEdge Class Methods
    For a list of all members of this type, see TopologyEdge members.
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public MethodOverloaded.
    Public MethodGets the topology node at the from point of this edge. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverridden.  Gets a hash code for the current object.
    Public MethodGets the set of parents (polygon features) that cover this edge. If boundedByEdge is true, then only polygons lying to the left of the edge will be returned. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the parent feature(s) that spawn this topology element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Public MethodGets the set of parents (polygon features) that cover this edge. If boundedByEdge is true, then only polygons lying to the right of the edge will be returned. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the shape of this topology element. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Public MethodGets the topology node at the to point of this edge. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether this topology element has been visited. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Public Method Sets a value indicating whether this topology element has been visited. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Topology.TopologyElement)
    Top
