ArcGIS.Desktop.Mapping Namespace / ElevationProfileResult Class
Members Example
    Defines the result of calling Map.GetElevationProfileFromSurface().
    Object Model
    ElevationProfileResult ClassPolyline Class
    Syntax
    Public Class ElevationProfileResult
    public class ElevationProfileResult
    Example
    Get Elevation profile from the default ground surface
        // get the elevation profile for a polyline / set of polylines
        Polyline polyline = PolylineBuilderEx.CreatePolyline();
        MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
        List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
        var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline]);
        if (result.Status == SurfaceZsResultStatus.Ok)
            var polylineZ = result.Polyline;
            // process the polylineZ
            // get the elevation profile for a set of points
            result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints);
    Get Elevation profile from a specific surface
        // find a specific elevation surface layer
        var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        // use the specific elevation surface layer
        var zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline], eleLayer);
        if (zResult.Status == SurfaceZsResultStatus.Ok)
            var polylineZ = zResult.Polyline;
        zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints, eleLayer);
    Interpolate a line between two points and calculate the elevation profile
        int numPoints = 20;//Or any number of points you want to interpolate
                           // use a specific elevation surface
        // use the default ground elevation surface
        MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
        MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
        var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints);
        result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints, eleLayer);
    Show Elevation profile graph using an ElevationProfileResult
        var elevProfileResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, 10);
        if (elevProfileResult.Status != SurfaceZsResultStatus.Ok)
            return;
        if (!MapView.Active.CanShowElevationProfileGraph())
            return;
        // show the elevation profile using the result
        MapView.Active.ShowElevationProfileGraph(elevProfileResult);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.ElevationProfileResult
    Requirements
    ArcGIS Pro version: 3.4 or higher.
