ArcGIS.Desktop.Mapping Namespace / SurfaceInterpolationMethod Enumeration
Example Example
    Syntax
    Members
    MemberDescription
    Linear Linear interpolation. The default.
    NaturalNeighbor Natural neighbor interpolation.
    NaturalNeighborInverseDistanceWeight Inverse Distance Weight based on natural neighbors.
    NaturalNeighborZAverage Z closest to the average of all natural neighbor nodes.
    NaturalNeighborZMax Maximum Z of all natural neighbor nodes.
    NaturalNeighborZMin Minimum Z of all natural neighbor nodes.
    NaturalNeighborZNearest Z value of the nearest node.
    Example
    Interpolate Shape
      // Note: Needs QueuedTask to run
      // Note: Needs 3d Analyst license to run
        ArcGIS.Core.Geometry.Geometry output = null;
        // interpolate z values for a geometry
        if (tinLayer.CanInterpolateShape(polyline))
          output = tinLayer.InterpolateShape(polyline, SurfaceInterpolationMethod.NaturalNeighbor);
        if (output != null)
          // process the output
        // densify the shape before interpolating
        if (tinLayer.CanInterpolateShape(polygon))
          output = tinLayer.InterpolateShape(polygon, SurfaceInterpolationMethod.Linear, 0.01, 0);
        if (output != null)
    Interpolate Shape vertices
        // interpolate z values at the geometry vertices only
        Geometry output = tinLayer.InterpolateShapeVertices(polyline, SurfaceInterpolationMethod.NaturalNeighbor);
        if (output != null)
        // or use a different interpolation method
        output = tinLayer.InterpolateShapeVertices(polyline, SurfaceInterpolationMethod.Linear);
    Interpolate Z at an x,y location
        // interpolate values at the specified x,y location
        double z = tinLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.NaturalNeighborZNearest);
        z = tinLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.Linear);
    Get 3D length of multipart by interpolating heights
        // interpolate heights and calculate the sum of 3D distances between the vertices
        double length3d = tinLayer.GetSurfaceLength(polygon, SurfaceInterpolationMethod.NaturalNeighbor);
        length3d = tinLayer.GetSurfaceLength(polyline, SurfaceInterpolationMethod.NaturalNeighborZNearest);
        length3d = tinLayer.GetSurfaceLength(polygon, SurfaceInterpolationMethod.NaturalNeighbor, 0.01, 0);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.SurfaceInterpolationMethod
    Requirements
    ArcGIS Pro version: 3.4 or higher.
