| Name | Description | |
![]() | AllowDrapingOnIntegratedMesh | Gets or sets a value indicating whether layer can be draped on integrated mesh. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Attribution | Gets or sets the attribution text that appears on a map that draws this layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | BlendingMode | Gets or sets the blending mode for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Charts | Gets or sets identifier the layer's charts. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | CustomProperties | Gets or sets the custom properties of the layer. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Description | Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | DisplayCacheType | Gets or sets the display cache type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | EnableLayerEffects | Gets or sets a value indicating whether to enable any type of effects on the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Expanded | Gets or sets a value indicating whether this layer is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Layer3DProperties | Gets or sets the 3D layer properties. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerEffects | Gets or sets the layer effects for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerElevation | Gets or sets the layer elevation. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerMasks | Gets or sets the URIs of the layers used as masks. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Layers | Gets or sets the layer URIs of the child layers. |
![]() | LayerScaleVisibilityOptions | Gets or sets the layer's scale visibility options. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerTemplate | Gets or sets the layer template. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerType | Gets or sets the map layer type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MaxDisplayCacheAge | Gets or sets the maximum display cache age. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MaxScale | Gets or sets the maximum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MetadataURI | Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | MinScale | Gets or sets the minimum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Name | Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | PopupInfo | Gets or sets the pop-up info. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RasterizeOnExport | Gets or sets a value indicating whether layer should be rasterized when exporting. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RefreshRate | Gets or sets the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RefreshRateUnit | Gets or sets the units for the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Searchable | Gets or sets a value indicating whether or not this layer should be included in the search. This property is honored only by layers that support search. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ServiceLayerID | Gets or sets identifier that will be used to identify the layer in server. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowLegends | Gets or sets a value indicating whether or not to show legends. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowMapTips | Gets or sets a value indicating whether or not the value of the display field or expression is shown when hovering over a layer in the view. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowPopups | Gets or sets a value indicating whether or not to show pop-ups. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | SourceModifiedTime | Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourcePortalUrl | Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourceURI | Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | StandaloneTables | Gets or sets the standalone tables as an array of table repository paths. |
![]() | Transparency | Gets or sets the transparency of the layer as a percentage. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | URI | Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | UseSourceMetadata | Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | UseVisibilityTimeExtent | Gets or sets a value indicating whether or not to use a fixed time extent for layer visibility. When true, the map time must overlap this extent for the layer to be visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Visibility | Gets or sets a value indicating whether or not this layer is visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | VisibilityTimeExtent | Gets or sets the fixed time extent for layer visibility. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | WebMapLayerID | Gets or sets an identifier that will be used to identify the layer in a web map. This value is present if the layer originated in a web map and facilitates matching the layer back to its origin when updating the web map. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
