ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / AddMassPointsZ Method / AddMassPointsZ(IEnumerable<Coordinate3D>,Int32,SpatialReference) Method
The coordinates to add.
The tag value for the new nodes. A value of 0 will result in no tag assignment.
The spatial reference of the coordinates. If it is the same as the TIN spatial reference, you can pass null.
    Adds coordinates as nodes to the TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub AddMassPointsZ( _
       ByVal coordinates As IEnumerable(Of Coordinate3D), _
       ByVal tagValue As Integer, _
       Optional ByVal spatialReference As SpatialReference _
    Parameters
    coordinates
    tagValue
    spatialReference
    Exceptions
    ExceptionDescription
    The coordinates parameter is null.
    The editor is not in edit mode.
    Remarks
    The z-values of the input coordinates are used for the TIN.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
