ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigationProjectItem Class / GetInvestigation Method
Example
    Returns a knowledge graph investigation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetInvestigation() As KnowledgeGraphInvestigation
    public KnowledgeGraphInvestigation GetInvestigation()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Open an existing investigation
      // open an existing investigation
      var investigationProjectItems = Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>();
      var investigationProjectItem = investigationProjectItems.FirstOrDefault(ipi => ipi.Name.Equals("myInvestigation"));
      await QueuedTask.Run(() =>
        KnowledgeGraphInvestigation investigation = investigationProjectItem.GetInvestigation();
        ProApp.Panes.CreateInvestigationPaneAsync(investigation);
        // or
        investigation.OpenViewAsync();
      // or
      investigationProjectItem.OpenInvestigationPaneAsync();
    Get the panes for an investigation
        var panes = investigation.GetInvestigationPanes();
        foreach (var pane in panes)
          KnowledgeGraphInvestigationView kgView = pane.InvestigationView;
          // if it's the active investigation view
          if (kgView == KnowledgeGraphInvestigationView.Active)
            // do something
    Activate an existing investigation view
      //Confirm if investigation exists as a project item
      KnowledgeGraphInvestigationProjectItem investigationItem =
         Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>().FirstOrDefault(
                                                            item => item.Name.Equals("myInvestigation"));
      if (investigationItem != null)
           await QueuedTask.Run(() => investigationItem.GetInvestigation());
        // see if a view is already open that references the same investigation
        foreach (var investigationPane in ProApp.Panes.OfType<IKnowledgeGraphInvestigationPane>())
          //if there is a match, activate the view
          if (investigationPane.InvestigationView.Investigation == investigation)
            (investigationPane as Pane).Activate();
            return;
    Requirements
    ArcGIS Pro version: 3.5 or higher.
