ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigationView Class / Active Property
Example
    Active Property (KnowledgeGraphInvestigationView)
    Gets the active Knowledge Graph investigation view.
    Syntax
    Public Shared ReadOnly Property Active As KnowledgeGraphInvestigationView
    public static KnowledgeGraphInvestigationView Active {get;}
    Remarks
    Returns null if there is no active investigation view.
    Example
    Get the active KnowledgeGraphInvestigationView, KnowledgeGraphInvestigation
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        // perform some action
    Select entity, relationship types in an investigation view
      // get the active investigation view
      var iv = KnowledgeGraphInvestigationView.Active;
      // clear any TOC selection
      iv.ClearTOCSelection();
      // select entities
      List<string> entities = new List<string>();
      entities.Add("Person");
      entities.Add("Org");
      iv.SelectEntities(entities);
      // or select relationships
      List<string> relationships = new List<string>();
      relationships.Add("HasEmployee");
      iv.SelectRelationships(relationships);
      // or select a combination
      List<string> namedObjectTypes = new List<string>();
      namedObjectTypes.Add("Person");
      namedObjectTypes.Add("Org");
      namedObjectTypes.Add("HasEmployee");
      iv.SelectNamedObjectTypes(namedObjectTypes);
    Select records in an investigation view
      var serviceUri = iv.Investigation.ServiceUri;
      // build a dictionary of records
      string some_entity = "Entity_Type_Name";
      var dict = new Dictionary<string, List<long>>();
      //Each entry consists of the type name and corresponding lists of ids
      dict.Add(some_entity, new List<long>() { 1, 5, 18, 36, 78 });
      //Create the id set...
      var idSet = KnowledgeGraphLayerIDSet.FromDictionary(new Uri(serviceUri), dict);
      // select the records on the investigation view
      iv.SetSelectedRecords(idSet, SelectionCombinationMethod.New);
    Clear selected records in an investigation view
      // clear the selected records
      iv.ClearSelectedRecords();
    Get Selected records and open in a new link chart
      await QueuedTask.Run(() =>
        // get the investigation
        var inv = iv.Investigation;
        // get the set of selected records
        var idSet = iv.GetSelectedRecords();
        // view these records in a link chart
        var map = MapFactory.Instance.CreateLinkChart("myLinkChart", new Uri(inv.ServiceUri), idSet);
        ProApp.Panes.CreateMapPaneAsync(map);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
