ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / SelectSpatialData Method
Example
    Selects the existing set of spatial data in the knowledge graph layer on the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function SelectSpatialData( _
       ByVal mapView As MapView _
    ) As SelectionSet
    public static SelectionSet SelectSpatialData(
       MapView mapView
    Parameters
    mapView
    Return Value
    The set of spatial data as a SelectionSet
    Exceptions
    ExceptionDescription
    Map cannot be null.
    Map is not a link chart.
    Remarks
    Spatial data are entities with geometry and relationships that connect to two spatial entities.
    Example
    Non spatial data
      await QueuedTask.Run(() =>
        // display non spatial data
        MapView.Active.SetShowNonSpatialData(true);
        // select the current set of non spatial data
        var selNonSpatial = MapView.Active.SelectNonSpatialData();
        // perform some action
        // select the current set of spatial data
        var selSpatial = MapView.Active.SelectSpatialData();
        // perform some other action
    Requirements
    ArcGIS Pro version: 3.5 or higher.
