ArcGIS.Desktop.Mapping Namespace / LineOfSightParams Class / ObstructionsMultipatchFeatureClass Property
Example
    Gets and sets the multipatch feature class that defines additional obstructing features.
    Syntax
    Public Property ObstructionsMultipatchFeatureClass As FeatureClass
    public FeatureClass ObstructionsMultipatchFeatureClass {get; set;}
    Example
    Get Line of Sight
      tinLayer = null;
      MapPoint observerPoint = null;
      MapPoint targetPoint = null;
      CIMPointSymbol obstructionPointSymbol = null;
      CIMLineSymbol visibleLineSymbol = null;
      CIMLineSymbol invisibleLineSymbol = null;
      var losParams = new LineOfSightParams();
      losParams.ObserverPoint = observerPoint;
      losParams.TargetPoint = targetPoint;
      // add offsets if appropriate
      // losParams.ObserverHeightOffset = observerOffset;
      // losParams.TargetHeightOffset = targerOffset;
      // add obstruction feature class if appropriate (multipatch)
      //losParams.ObstructionsMultipatchFeatureClass = obsFeatureClass;
      // set output spatial reference
      losParams.OutputSpatialReference = MapView.Active.Map.SpatialReference;
      LineOfSightResult results = null;
      try
        // Note: Needs QueuedTask to run
          if (tinLayer.CanGetLineOfSight(losParams))
            results = tinLayer.GetLineOfSight(losParams);
      catch (Exception)
        // handle exception
      if (results != null)
        bool targetIsVisibleFromObserverPoint = results.IsTargetVisibleFromObserverPoint;
        //These properties are not used. They will always be false
        // results.IsTargetVisibleFromVisibleLine;
        // results.IsTargetVisibleFromInvisibleLine;
        if (results.VisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, visibleLineSymbol.MakeSymbolReference());
        if (results.InvisibleLine != null)
          MapView.Active.AddOverlay(results.VisibleLine, invisibleLineSymbol.MakeSymbolReference());
        if (results.ObstructionPoint != null)
          MapView.Active.AddOverlay(results.ObstructionPoint, obstructionPointSymbol.MakeSymbolReference());
    Requirements
    ArcGIS Pro version: 3.5 or higher.
