ArcGIS.Desktop.Mapping Namespace / MapView Class / ElevationProfileGraphAdded Event
Example
    Occurs when the elevation profile graph is added.
    Syntax
    Public Event ElevationProfileGraphAdded As EventHandler
    public event EventHandler ElevationProfileGraphAdded
    Example
    Access the ElevationProfileGraph when added
        // subscribe to the Added, Removed events for the elevation profile graph
        mapView.ElevationProfileGraphAdded += Mv_ElevationProfileGraphAdded;
        mapView.ElevationProfileGraphRemoved += Mv_ElevationProfileGraphRemoved;
        //Handles the event triggered when an elevation profile graph is removed.
        void Mv_ElevationProfileGraphRemoved(object sender, EventArgs e)
            //TODO: handle the removal of the elevation profile graph
        //Handles the event triggered when an elevation profile graph is added to the active map view.
        void Mv_ElevationProfileGraphAdded(object sender, EventArgs e)
            // get the elevation profile graph from the view
            // this will be non-null since we are in a ElevationProfileGraphAdded handler
            var mv = MapView.Active;
            var graph = mv.GetElevationProfileGraph();
            // subscribe to the ContentLoaded event
            graph.ContentLoaded += Graph_ContentLoaded;
        // Handles the event triggered when the elevation profile graph content is loaded.
        void Graph_ContentLoaded(object sender, EventArgs e)
            var graph = sender as ArcGIS.Desktop.Mapping.ElevationProfileGraph;
            // get the elevation profile geometry
            var polyline = graph.Geometry;
            // get the elevation profile statistics
            var stats = graph.ElevationProfileStatistics;
    Requirements
    ArcGIS Pro version: 3.5 or higher.
