Public Shadows Property MapMemberPosition As MapMemberPosition
public new MapMemberPosition MapMemberPosition {get; set;}
If the set of layers to be added are specified by a set of LayerCreationParams objects, then this property overrides the individual MapMemberPosition properties.
//Uris to the datasets for the layers to be created
var uriShp = new Uri(@"c:\data\roads.shp");
var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
// Create a list of URIs to be used for creating multiple layers
var uris = new List<Uri>() { uriShp, uriSde, uri }; ;
// set the index and visibility
var blkParams = new BulkLayerCreationParams(uris);
blkParams.MapMemberPosition = MapMemberPosition.Index;
blkParams.MapMemberIndex = 2;
blkParams.IsVisible = false;
// Create multiple layers using the BulkLayerCreationParams
//Note: Needs QueuedTask to run
var layers = LayerFactory.Instance.CreateLayers(blkParams, MapView.Active.Map);
var lcpShp = new FeatureLayerCreationParams(uriShp);
lcpShp.Name = "Roads";
lcpShp.IsVisible = false;
lcpShp.DefinitionQuery = new DefinitionQuery("shpQuery", "OBJECTID > 10");
var lcpSde = new FeatureLayerCreationParams(uriSde);
lcpSde.Name = "Census Polygons";
lcpSde.IsVisible = true;
var lcpService = new FeatureLayerCreationParams(uri);
lcpService.Name = "Shelters";
lcpService.IsVisible = true;
// set some renderer here ...
//lcpService.RendererDefinition = ...
var lcps = new List<FeatureLayerCreationParams>();
lcps.Add(lcpShp);
lcps.Add(lcpSde);
lcps.Add(lcpService);
var blkParams = new BulkLayerCreationParams(lcps);
// set the positioning on the BulkLayerCreationParams
blkParams.MapMemberIndex = 0;
lcps.Add(lcpShp);
lcps.Add(lcpSde);
// set the rollback behavior
// - rollback if one or more layers cannot be created due to an invalid data source
blkParams.RollbackBehavior = LayerCreationRollbackBehavior.RollbackOnMissingLayers;
