Public Function GetFallbackTools() As IReadOnlyList(Of String)
public IReadOnlyList<string> GetFallbackTools()
Return Value
List of tool damlIDs
// A fallback tool is the tool that will be activated when an editing tool
// is deactivated; (when the Escape key press for example)
// To register a tool as a fallback tool, add the following into your
// add-in's config.daml file
// <updateModule refID = "esri_editing_EditingModule">
// <menus>
// <updateMenu refID = "esri_editing_DefaultTools">
// <insertButton refID = "MyAddIn_MyCustomTool"/>
// </updateMenu>
// </menus>
// </updateModule>
var options = ApplicationOptions.EditingOptions;
// get the list of fallback tools that are registered
var fallbackTools = options.GetFallbackTools();
// get the current fallback tool
var fallbackTool = options.FallbackTool;
// set the fallback tool
// (MyAddIn_MyCustomTool must be added to the "esri_editing_DefaultTools" list)
options.FallbackTool = "MyAddIn_MyCustomTool";
