Public Function MaterializePath( _ ByVal pathIndex As Long _ ) As Nullable(Of ResultPath)
public Nullable<ResultPath> MaterializePath( long pathIndex )
Parameters
- pathIndex
- The index of the path (0 <= pathIndex < CountPaths).
| Exception | Description |
| System.ArgumentOutOfRangeException | When the index is out of range. |
//using ArcGIS.Core.Data.Knowledge.Extensions;
await QueuedTask.Run(async () =>
var ffp_config = new CIMFilteredFindPathsConfiguration();
ffp_config.Name = "List out FFP Results by Path Length, Min Cost, Max Cost";
//set up config
var results = kg.RunFilteredFindPaths(ffp_config);
if (results.CountPaths == 0)
System.Diagnostics.Debug.WriteLine("FFP returned no paths");
return;
//print out paths by increasing length, min cost, max cost
var path_by_len_indices = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingPathLength
.Select(idx => idx.index);
var path_by_min_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMinPathCost
var path_by_max_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMaxPathCost
var x = 0;
StringBuilder sb = new StringBuilder();
foreach (var path_indeces in new List<IEnumerable<long>> {
path_by_len_indices,
path_by_min_cost,
path_by_max_cost})
if (x == 0)
sb.AppendLine($"Paths by length: {path_by_len_indices.Count()}");
else if (x == 1)
sb.AppendLine($"Paths by min cost: {path_by_min_cost.Count()}");
else if (x == 2)
sb.AppendLine($"Paths by max cost: {path_by_max_cost.Count()}");
x++;
foreach (var path_idx in path_indeces)
var path = (ResultPath)results.MaterializePath(path_idx);
sb.AppendLine(
$"Path[{path_idx}] length: {path.Length}, min: {path.MinCost} max: {path.MaxCost}");
var g = 0;
foreach (var rel_group in path.RelationshipGroups)
var first_entity = $"({rel_group.FirstEntity.TypeName}:{rel_group.FirstEntity.Uid})";
var second_entity = $"({rel_group.SecondEntity.TypeName}:{rel_group.SecondEntity.Uid})";
foreach (var relation in rel_group.Relationships)
sb.Append($" [{g++}] ");
var arrow = relation.SameDirectionAsPath ? "->" : "<-";
var rel_uid = FormatUID(relation.Relationship.Uid.ToString());
sb.Append($"{first_entity} '\r\n\t{relation.Relationship.TypeName}:{rel_uid}' {arrow}\r\n" +
$"\t\t{second_entity}");
sb.Append($" cost: {relation.Relationship.Cost}\r\n");
string FormatUID(string id)
id = id.ToUpperInvariant();
if (!id.StartsWith('{'))
id = '{' + id;
if (!id.EndsWith('}'))
id += '}';
return id;
ffp_config.Name = "List out FFP Results Origin, Destination, Other Entities";
//set up config
return;
var x = 0;
path_by_min_cost,
path_by_max_cost})
if (x == 0)
sb.AppendLine($"Entities by length: {path_by_len_indices.Count()}");
else if (x == 1)
sb.AppendLine($"Entities by min cost: {path_by_min_cost.Count()}");
else if (x == 2)
sb.AppendLine($"Entities by max cost: {path_by_max_cost.Count()}");
x++;
sb.AppendLine(
var sorted_set = new SortedSet<ulong>();
sorted_set.Add((ulong)path_idx);
var per = results.ExtractPathsEntitiesAndRelationships(sorted_set);
var origin_dest_uids = new List<string>();
var sep = "";
sb.Append(" Origin EntitiesUIDs: ");
foreach (var idx in per.PathsOriginEntitiesUIDsIndexes)
//See 'List out FFP Results by Path Length, Min Cost, Max Cost' for
//FormatID method above
var uid = FormatID(per.EntitiesUIDs[idx].ToString());
origin_dest_uids.Add(uid);
var origin =
$"{sep}{per.EntityTypeNames[per.EntityTypes[idx]]}:{uid}";
sep = ", ";
sb.Append($"{origin}");
sb.AppendLine("");
sep = "";
sb.Append(" Destination EntitiesUIDs: ");
foreach (var idx in per.PathsDestinationEntitiesUIDsIndexes)
var dest =
sep = ", ";
sb.Append($"{dest}");
sb.AppendLine("");
sep = "";
var idx2 = 0;
sb.Append(" Other EntitiesUIDs: ");
bool wereAnyOthers = false;
foreach (var raw_uid in per.EntitiesUIDs)
var uid = FormatID(raw_uid.ToString());
if (!origin_dest_uids.Contains(uid))
var other =
$"{sep}{per.EntityTypeNames[per.EntityTypes[idx2]]}:{uid}";
sep = ", ";
sb.Append($"{other}");
wereAnyOthers = true;
idx2++;
if (!wereAnyOthers)
sb.Append(" <<none>>");
//sb.AppendLine("");
var entity_str = sb.ToString();
System.Diagnostics.Debug.WriteLine(entity_str);
sb.Clear();
sep = "";
