ArcGIS.Core.Data.Knowledge.Analytics Namespace / PathsEntitiesAndRelationships Class / ToKnowledgeGraphIDSet Method
The type of result content to include in the id set
Example
    ToKnowledgeGraphIDSet Method (PathsEntitiesAndRelationships)
    Converts the entities and relationships from the FFP results into a ArcGIS.Core.Data.Knowledge.KnowledgeGraphIDSet.
    Syntax
    Public Function ToKnowledgeGraphIDSet( _
       ByVal resultContent As KGResultContentFromFFP _
    ) As KnowledgeGraphIDSet
    public KnowledgeGraphIDSet ToKnowledgeGraphIDSet(
       KGResultContentFromFFP resultContent
    Parameters
    resultContent
    Return Value
    Remarks
    Note: Use KGResultContentFromFFP.EntitiesAndRelationships to update both entities and relationships on a link chart (eg via map.AppendToLinkChart(kgLayerIdSet) or via MapFactory.Instance.CreateLinkChart("name", kg, kgLayerIdSet) and use KGResultContentFromFFP.OnlyPathsOriginEntities to return the subset of entity uids that can be used as link chart root nodes.
    Example
    Create Link Chart from FFP Results
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(async () =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "Create Link Chart from FFP Results";
        //set up config
        var results = kg.RunFilteredFindPaths(ffp_config);
        var pathsEntitiesAndRelationships = results.ExtractPathsEntitiesAndRelationships(null);
        //Create a KG layer id set
        var kgLayerIdSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
          pathsEntitiesAndRelationships.ToKnowledgeGraphIDSet(
            KGResultContentFromFFP.EntitiesAndRelationships));
        //Create a brand new link chart with the results and show it
        var linkChart = MapFactory.Instance.CreateLinkChart("KG Intro", kg, kgLayerIdSet);
        var mapPane = await FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
        var linkChartView = mapPane.MapView;
        //Change layout algo to match the default used by the UI after FFP
        await linkChartView.SetLinkChartLayoutAsync(
          KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom);
        //Set root nodes - they correspond to the origin nodes of the result paths
        var kgLayerIdSetForRootNodes = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
            KGResultContentFromFFP.OnlyPathsOriginEntities));
        //To correctly identify the ids in the link chart we must change the ids
        //from Geodatabase oids returned in the KnowledgeGraphLayerIDSet to the
        //temporary/synthetic oids used by layers in the link chart...
        var kg_layer = linkChart.GetLayersAsFlattenedList().OfType<KnowledgeGraphLayer>().First();
        var mapMembers = kg_layer.GetMapMembersAsFlattenedList();
        var oidDict = kgLayerIdSetForRootNodes.ToOIDDictionary();
        var mmDict = new Dictionary<MapMember, List<long>>();
        foreach (var kvp in oidDict)
          var named_type = kvp.Key;
          foreach (var mm in mapMembers)
            if (mm is LinkChartFeatureLayer fl_lc && fl_lc.IsEntity)
              if (fl_lc.GetTypeName().ToLower() == named_type.ToLower())
                var lc_oids = new List<long>();
                //these oids are from the geodatabase
                var oid_field = $"{fl_lc.GetTypeName()}.objectid";
                var id_list = string.Join(',', kvp.Value.ToArray());
                var where = $"{fl_lc.GetTypeName()}.objectid IN ({id_list})";
                var qf = new ArcGIS.Core.Data.QueryFilter()
                  WhereClause = where,
                  SubFields = $"LC.OID,{oid_field}"//the 'LC.OID' oids are the ones
                                                   //we need for the mapmember id set
                                                   //in the link chart
                var rc = fl_lc.Search(qf);
                var oid_idx = rc.FindField(oid_field);
                while (rc.MoveNext())
                  var oid = (long)rc.Current[oid_idx];
                  var lc_oid = rc.Current.GetObjectID();
                  lc_oids.Add(lc_oid);
                rc.Dispose();
                mmDict[fl_lc] = lc_oids;
                break;
        var mmIdSet = MapMemberIDSet.FromDictionary(mmDict);
        linkChartView.SetRootNodes(mmIdSet);
    Append to Link Chart from FFP Results
      var linkChartView = MapView.Active;
        ffp_config.Name = "Append to Link Chart from FFP Results";
        //set up config
        var map = linkChartView.Map;
        if (!map.CanAppendToLinkChart(kgLayerIdSet))
          return;//not compatible
        map.AppendToLinkChart(kgLayerIdSet);
        //switch layout algo
        var algo = linkChartView.GetLinkChartLayout();
        if (algo != KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom)
        //To set link chart root nodes see 'Create Link Chart from FFP Results'
    Requirements
    ArcGIS Pro version: 3.6 or higher.
