ArcGIS.Core.CIM Namespace / CIMMarkerPlacementAlongLineSameSize Class
    CIMMarkerPlacementAlongLineSameSize Class Properties
    For a list of all members of this type, see CIMMarkerPlacementAlongLineSameSize members.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to angle the marker to the line. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets where the pattern should end relative to the ending point of the geometry. The entire pattern is shifted along the line for the specified distance. Negative numbers shift to the left and positive numbers shift to the right. This is only applied if the Endings property is set to Custom. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacementAlongLine)
    Public Property Gets or sets how markers are placed at the end points of a line. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacementAlongLine)
    Public Property Gets or sets a value indicating whether to keep the marker upright. This is only considered if AngleToLine is true. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets the offset. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets where the pattern should begin relative to the starting point of the geometry. The entire pattern is shifted along the line for the specified distance. Negative numbers shift to the left and positive numbers shift to the right. This is only applied if the Endings property is set to No Constraint or Custom. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacementAlongLine)
    Public Property Gets or sets the numeric pattern that defines the sequence of placed markers and the length of space between them. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacementAlongLine)
    Public Property Gets or sets a value indicating whether to consider individual geometry parts or the whole geometry. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Top
