ArcGIS.Core.CIM Namespace / CIMMarkerPlacementAlongLineVariableSize Class
    CIMMarkerPlacementAlongLineVariableSize Class Properties
    For a list of all members of this type, see CIMMarkerPlacementAlongLineVariableSize members.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to angle the marker to the line. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets how markers are placed at control points.
    Public Property Gets or sets how markers are placed at the end points of a line.
    Public Property Gets or sets a value indicating whether to keep the marker upright. This is only considered if AngleToLine is true. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets the maximum random offset.
    Public Property Gets or sets the largest size of the marker to be placed on the line. The value is expressed as a ratio.
    Public Property Gets or sets the smallest size of the marker to be placed on the line. The value is expressed as a ratio.
    Public Property Gets or sets the number of different sizes of markers to be placed on the line.
    Public Property Gets or sets the offset. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets the numeric pattern that defines the sequence of placed markers and the length of space between them.
    Public Property Gets or sets a value indicating whether to consider individual geometry parts or the whole geometry. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the starting value for generating a random number. This random number is used by the Randomization property to determine which size a marker will receive. This is only used if the VariationMethod is set to Random.
    Public Property Gets or sets the order in which the change of size in the markers should occur.
    Top
