ArcGIS.Desktop.Mapping Namespace / LasDatasetLayer Class / SetSelectableClassCodes Method
The class codes that are selectable. To specify that all class codes are selectable, pass an empty list.
Example
    Sets the class codes that are selectable. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetSelectableClassCodes( _
       ByVal classCodes As IEnumerable(Of Integer) _
    public void SetSelectableClassCodes(
       IEnumerable<int> classCodes
    Parameters
    classCodes
    Exceptions
    ExceptionDescription
    The input parameter class codes list is null.
    Remarks
    This setting is not preserved in the layer's CIM definition. It is only stored for the active map session.
    Example
    Selection Settings
      // must be on MCT
      // configure the LAS selection settings
      // set visible points and a specific set of classification codes selectable
      lasDatasetLayer.SetSelectVisiblePoints(true);
      lasDatasetLayer.SetSelectableClassCodes(new List<int>() { 3, 4, 5 });
      // this example sets all classification codes selectable
      lasDatasetLayer.SetSelectableClassCodes(new List<int>());
      // get the current LAS selection settings
      var canSelectVisible = lasDatasetLayer.GetSelectVisiblePoints();
      var selectableClassCodes = lasDatasetLayer.GetSelectableClassCodes();
    Requirements
    ArcGIS Pro version: 3.6 or higher.
