ArcGIS.Desktop.Mapping Namespace / LasPointPipelineSelectionFilter Class
Members Example
    Represents the pipeline filter used when selecting points in a LAS dataset layer. The pipeline filter selects a series of points along a line based on the original selection until the filter parameters are exceeded.
    See LasDatasetLayer.SelectAsync.
    Object Model
    LasPointPipelineSelectionFilter ClassGeometry Class
    Syntax
    Public Class LasPointPipelineSelectionFilter
       Inherits LasPointSelectionFilter
    public class LasPointPipelineSelectionFilter : LasPointSelectionFilter
    Example
    Select using LasPointPipelineSelectionFilter
      // must be on MCT
      var pipelineFilter = new LasPointPipelineSelectionFilter();
      pipelineFilter.VisiblePoints = true;
      pipelineFilter.ClassCodes = new List<int>();  // empty list means all classification codes
      pipelineFilter.FilterGeometry = polygon;
      // configure a few of the properties and accept defaults for others
      pipelineFilter.ApplyWindCorrection = true;
      pipelineFilter.MinimumLength = 25;  // meters
      var pipelineSelCount = await lasDatasetLayer.SelectAsync(pipelineFilter, SelectionCombinationMethod.New);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LasPointSelectionFilter
          ArcGIS.Desktop.Mapping.LasPointPipelineSelectionFilter
    Requirements
    ArcGIS Pro version: 3.6 or higher.
