ArcGIS.Desktop.Mapping Namespace / LasPointPlaneSelectionFilter Class
Members Example
    Represents the plane filter used when selecting points in a LAS dataset layer. The plane filter selects a series of points based on the original selection until the filter parameters are exceeded.
    See LasDatasetLayer.SelectAsync.
    Object Model
    LasPointPlaneSelectionFilter ClassGeometry Class
    Syntax
    Public Class LasPointPlaneSelectionFilter
       Inherits LasPointSelectionFilter
    public class LasPointPlaneSelectionFilter : LasPointSelectionFilter
    Example
    Select using LasPointPlaneSelectionFilter
      // must be on MCT
      var planeFilter = new LasPointPlaneSelectionFilter();
      planeFilter.VisiblePoints = true;
      planeFilter.ClassCodes = new List<int>();  // empty list means all classification codes
      planeFilter.FilterGeometry = polygon;
      planeFilter.ClusteringDistance = 0.3; // meters
      planeFilter.MaximumDistance = 500;
      planeFilter.PlaneTolerance = 0.152; // meters
      var planeSelCount = await lasDatasetLayer.SelectAsync(planeFilter, SelectionCombinationMethod.New);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LasPointSelectionFilter
          ArcGIS.Desktop.Mapping.LasPointPlaneSelectionFilter
    Requirements
    ArcGIS Pro version: 3.6 or higher.
