| Name | Description | |
![]() | Description | Gets or sets a string that describes the element in detail. |
![]() | DisplayCount | Gets or sets an integer that indicates the maximum number of records to display. If set (or defaulted) to -1, there is no maximum. |
![]() | DisplayType | Gets or sets how related records should be displayed. |
![]() | EditableExpressionName | Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is editable. When the expression evaluates to 'false' the element is not editable. If the referenced related table is not editable, the editable expression is ignored and the element is not editable. |
![]() | Label | Gets or sets a string value indicating what the element represents. |
![]() | OrderByFields | Gets or sets the array of orderByField objects indicating the display order for the related records, and whether they should be sorted in ascending or descending order. |
![]() | RelationshipName | Gets or sets the name of the relationship as defined in the feature layer definition. |
![]() | VisibilityExpressionName | Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is displayed. When the expression evaluates to 'false' the element is not displayed. If no expression is provided, the default behavior is that the element is displayed. |
