ArcGIS.Core.CIM Namespace / CIMMultipatchFeatureTemplate Class
    CIMMultipatchFeatureTemplate Class Methods
    For a list of all members of this type, see CIMMultipatchFeatureTemplate members.
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMultipatchFeatureTemplate.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMultipatchFeatureTemplate with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMultipatchFeatureTemplate and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Extension Methods
     NameDescription
    Public Extension Method Add a new model to a CIMMultipatchFeatureTemplate. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Allows a construction tool on the template.
    Public Extension Method Excludes a construction tool from the template.
    Public Extension Method Gets the default construction tool.
    Public Extension Method Gets the excluded construction tools on the template.
    Public Extension Method Read the Tags from a CIMEditingTemplate.
    Public Extension Method Sets the default construction tool.
    Public Extension Method Sets the excluded construction tools on the template.
    Public Extension Method Write an array of tags to a CIMEditingTemplate.
    Top
