GetAllQueryDefinitions Method
Gets all the
ArcGIS.Core.CIM.CIMKnowledgeGraphQueryDefinitions for this investigation. This method must be called on the MCT. Use QueuedTask.Run.
Retrieve Investigation Query Definitions
// access the currently active knowledge graph investigation view
KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
KnowledgeGraphInvestigation investigation = activeView?.Investigation;
if (investigation != null)
await QueuedTask.Run(() =>
// get all the query defintiions
var queries = investigation.GetAllQueryDefinitions();
// get a specific query definition
var myQuery = investigation.GetQueryDefinition("Query1");
ArcGIS Pro version: 3.7 or higher.
