ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigation Class / GetFilteredFindPathsConfiguration Method
The name of the filtered find paths configuration to retrieve. This corresponds to ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration.Name.
Example
    Gets the ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration with the specified name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetFilteredFindPathsConfiguration( _
       ByVal filteredFindPathsConfigurationName As String _
    ) As CIMFilteredFindPathsConfiguration
    Parameters
    Return Value
    A ArcGIS.Core.CIM.CIMKnowledgeGraphQueryDefinition. If no filtered find paths configuration matching the name is found, null is returned. This method is case insensitive.
    Exceptions
    ExceptionDescription
    Example
    Retrieve Investigation Filtered Find Paths Configurations
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        await QueuedTask.Run(() =>
          // get all the configurations
          var configurations = investigation.GetAllFilteredFindPathsConfigurations();
          // get a specific FFP configuration
          var myConfiguration = investigation.GetFilteredFindPathsConfiguration("FFPConfig1");
    Requirements
    ArcGIS Pro version: 3.7 or higher.
