ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigation Class / ImportFilteredFindPathsConfiguration Method
A filtered find paths configuration file.
Example
    Import a filtered find paths configuration from a filtered find paths configuration file (*.ffpcfg) and add it to the investigation.
    Syntax
    Public Function ImportFilteredFindPathsConfiguration( _
       ByVal filePath As String _
    ) As Task(Of CIMFilteredFindPathsConfiguration)
    public Task<CIMFilteredFindPathsConfiguration> ImportFilteredFindPathsConfiguration(
       string filePath
    Parameters
    filePath
    Return Value
    A Task to a ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration. If the import is not successful, then null is returned.
    Exceptions
    ExceptionDescription
    The filePath is null or empty.
    An invalid file Path was supplied.
    Remarks
    Filtered find paths configuration names must be unique within an investigation. If the name of the ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration to be imported already exists in the investigation, then a numerical suffix is applied to the name of the new ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration to ensure it is unique. This check is case insensitive.
    Example
    Import a Filtered Find Paths Configuration
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        string pathName = @"d:\data\EntityFFPConfig.ffpcfg";
        // import from ffpcfg
        var ffpConfig = await investigation.ImportFilteredFindPathsConfiguration(pathName);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
