RenameFilteredFindPathsConfiguration Method
Renames the
ArcGIS.Core.CIM.CIMFilteredFindPathsConfiguration with the specified name. This method must be called on the MCT. Use QueuedTask.Run.
Rename a Filtered Find Paths Configuration
// access the currently active knowledge graph investigation view
KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
KnowledgeGraphInvestigation investigation = activeView?.Investigation;
if (investigation != null)
await QueuedTask.Run(() =>
// rename the FFPConfig
investigation.RenameFilteredFindPathsConfiguration("FFPConfig1", "FFPConfig_POI");
ArcGIS Pro version: 3.7 or higher.
