ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigation Class / UpdateQueryDefinition Method / UpdateQueryDefinition(String,String) Method
The name of the ArcGIS.Core.CIM.CIMKnowledgeGraphQueryDefinition to update. This corresponds to ArcGIS.Core.CIM.CIMKnowledgeGraphQueryDefinition.Name.
The new openCypher queryText for the ArcGIS.Core.CIM.CIMKnowledgeGraphQueryDefinition .
Example
    Updates the specified ArcGIS.Core.CIM.CIMKnowledgeGraphQueryDefinition with the new openCypher text. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub UpdateQueryDefinition( _
       ByVal queryDefinitionName As String, _
       ByVal newOpenCypherText As String _
    public void UpdateQueryDefinition(
       string queryDefinitionName,
       string newOpenCypherText
    Parameters
    queryDefinitionName
    newOpenCypherText
    Exceptions
    ExceptionDescription
    queryDefinitionName is null or empty.
    The queryDefinitionName does not exist in the investigation.
    Remarks
    This method is case sensitive.
    Example
    Update Query Definition
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        await QueuedTask.Run(() =>
          // return the first 20 entities
          var newOpenCypherQuery = "MATCH (n) RETURN n LIMIT 20\"";
          // update the open cypher query for a query definition
          investigation.UpdateQueryDefinition("Query1", newOpenCypherQuery);
          // or update other properties
          var myQuery = investigation.GetQueryDefinition("Query1");
          if (myQuery != null)
            myQuery.ProvenanceBehavior = ProvenanceBehavior.Exclude;
            myQuery.OpenCypherQuery = "MATCH (n) RETURN n LIMIT 30\"";
            investigation.UpdateQueryDefinition(myQuery);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
